[gdal-dev] Problem reading shapefile via /vsizip
Even Rouault even.rouault at mines-paris.org
Fri Jul 13 03:19:14 PDT 2012
Selon "Smith, Michael ERDC-CRREL-NH" <Michael.Smith at usace.army.mil>:
Michael,
Do you use GDAL trunk, or 1.9.X ? It might be possible that fixes for subtle
bugs could have pushed in trunk, but I'm not 100% positive that it is the case.
Did you try to turn "--debug on" to see if interesting messages appear ?
If the problem remains, please open a ticket in Trac so I have opportunity to
check that later.
Best regards,
Even
