[gdal-dev] New OGR driver to read OpenStreetMap .osm / .pbf files
Even Rouault even.rouault at mines-paris.org
Fri Jul 20 11:10:16 PDT 2012
> > However, select with SQL feels sub-optimal.
> Yes, when you use ogr2ogr with explicit layer names, there are
> optimizations. For example, when you only specify the layer 'points', the
> OSM driver will not even try to index the nodes into the temporary
> database because it is not needed. However, as you noticed, there is not
> yet any optimization when a SQL request is specified.
Optimization for SQL request added in r24690
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120720/aa61a3f3/attachment.html>
