[gdal-dev] Compiling GDAL JNI libraries
Sunil Padda sunilkp at yahoo-inc.com
Tue Jul 24 03:55:45 PDT 2012
I am trying to compile GDAL with Java bindings, but am facing issues.
Here is what I have done:
1. Download gdal source from http://trac.osgeo.org/gdal/wiki/DownloadSource
2. Build gdal libraries
     cd gdal
     ./configure
     make
     sudo make install
3. Install SWIG
4. Update JAVA_HOME in gdal/swig/java/java.opt
5. Build gdal JNI
     cd gdal/swig/java
     make
I am seeing errors like this:
wanthunger-dx 16:00:56 ~/downloads/gdal-1.9.1/swig/java $ make
mkdir -p org/gdal/gdal
mkdir -p org/gdal/gdalconst
mkdir -p org/gdal/ogr
mkdir -p org/gdal/osr
/bin/sh /home/sunilkp/downloads/gdal-1.9.1/libtool --mode=compile
--tag=CXX g++ -fno-strict-aliasing -g -O2  -Wall
-Wdeclaration-after-statement -I/home/sunilkp/downloads/gdal-1.9.1/port
-I/home/sunilkp/downloads/gdal-1.9.1/gcore
-I/home/sunilkp/downloads/gdal-1.9.1/alg
-I/home/sunilkp/downloads/gdal-1.9.1/ogr
-I/home/sunilkp/downloads/gdal-1.9.1/ogr/ogrsf_frmts
-I"/home/y/libexec/jdk1.6.0"/include
-I"/home/y/libexec/jdk1.6.0"/include/linux -c gdal_wrap.cpp
libtool: compile:  g++ -fno-strict-aliasing -g -O2 -Wall
-I/home/y/libexec/jdk1.6.0/include
-I/home/y/libexec/jdk1.6.0/include/linux -c gdal_wrap.cpp  -fPIC -DPIC
-o .libs/gdal_wrap.o
cc1plus: warning: command line option "-Wdeclaration-after-statement" is
valid for C/ObjC but not for C++
gdal_wrap.cpp: In function `_jstring*
Java_org_gdal_gdal_gdalJNI_get_1Driver_1ShortName(JNIEnv*, _jclass*,
jlong)':
gdal_wrap.cpp:4600: error: `GDALDriverShadow_get_ShortName' was not
declared in this scope
gdal_wrap.cpp:4600: warning: unused variable
'GDALDriverShadow_get_ShortName'
I don't have experience in C++ or Make, so couldn't figure out how to
fix this. But, it looks like some problem with a) referenced gdal c++
headers/libraries or b) invalid compiler options
It would be great if you can help me fix this issue.
Thanks,
Sunil
