[gdal-dev] translate ecw to geotiff + tfw
Even Rouault even.rouault at mines-paris.org
Wed Jun 13 11:44:46 PDT 2012
Le mercredi 13 juin 2012 20:17:25, Steve G a écrit :
> I am attempting to use the translate function to convert from ecw to
> geotiff and the creation of an associated tfw file.  The geotiff is
> created, but it fails to create the tfw file.  I've tried many times, but
> always fails.  My syntax is as follows:
> gdal_translate -a_srs EPSG:2227 -co tfw=yes -of GTiff
> R:/GIS/GIS_Data/Aerials/65123.ecw R:/GIS/GIS_Data/Aerials/65123.tif
> When I do a similar operation with a sid file, the tfw is created.  Has
> anyone else experienced this problem with translating an ecw file type?
> Any suggestions?
I suspect that your ecw file has no associated geotransform matrix, which is
needed to write a TFW file. This could be confirmed if you post the output of
gdalinfo on your ecw file.
> Thanks in advance.
> Steve
> http://osgeo-org.1560.n6.nabble.com/translate-ecw-to-geotiff-tfw-tp4981248
> .html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
