[gdal-dev] convert .tif/.tfwx/.aux.xml to a geotiff?
Martin Ouellet
geomartino at gmail.com
Fri Jun 15 07:46:27 PDT 2012
I manually georeferenced some images in ArcGIS and at the end, I got a
.tfwx file and a aux.xml.
I wish to convert them into geotiff with the georeferenced info in the
header:
1) I've renamed the .tfwx into .tfw and run a gdal_translate. The command
didn't failed but the resulting image is not georeferenced at all
Is it possible to do that perhaps using the info in the .aux.xml file?
Thanks,
MartinO
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120615/25f0a2a8/attachment.html>
