[gdal-dev] convert .tif/.tfwx/.aux.xml to a geotiff?
Florent JITIAUX
fjitiaux at gmail.com
Sat Jun 16 00:46:54 PDT 2012
Hi Martin,
if you georeference your images manually you can use gdalwarp to do it or
set coordinates of images with gdal_translate.
Florent
2012/6/15 Martin Ouellet <geomartino at gmail.com>
> Hi,
> I manually georeferenced some images in ArcGIS and at the end, I got a
> .tfwx file and a aux.xml.
> I wish to convert them into geotiff with the georeferenced info in the
> header:
> 1) I've renamed the .tfwx into .tfw and run a gdal_translate. The command
> didn't failed but the resulting image is not georeferenced at all
> Is it possible to do that perhaps using the info in the .aux.xml file?
> Thanks,
> MartinO
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120616/ae67cc26/attachment.html>
