[gdal-dev] Cannot read NetCDF subdatasets
Paolo Corti
pcorti at gmail.com
Wed Jun 20 01:47:20 PDT 2012
On Tue, Jun 19, 2012 at 7:48 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> no... unless your system uses the hdf5 driver before the netcdf driver.
> If the netcdf driver detects a hdf5 file that ends with nc, nc2, nc4
> or cdf (the common extensions) then it opens it, else it passes it to
> the hdf5 driver.
> There is no other way of identifying hdf5 files that are not "netcdf-4" files.
> There is a test in the autotest suite that tests that the netcdf
> driver picks up netcdf-4 files but not other hdf5 files. If you do
> have the autotests installed, try to run the gdrivers/netcdf.py test.
> Can you send an example file to me?
The system, when opening the whole dataset uses hdf5 as the default.
At least, gdalinfo display the list of each subdataset like this:
Subdatasets:
SUBDATASET_1_NAME=HDF5:"/effisRisk/Data/Season-2012/Ecmwf/m05/Glb_20120528.nc4"://cf_DangerRisk
SUBDATASET_1_DESC=[10x640x1280] //cf_DangerRisk (32-bit floating-point)
SUBDATASET_2_NAME=HDF5:"/effisRisk/Data/Season-2012/Ecmwf/m05/Glb_20120528.nc4"://cf_FWI
SUBDATASET_2_DESC=[10x640x1280] //cf_FWI (32-bit floating-point)
When opening a subdatset it uses the netcdf as the default
If I specify NETCDF:dataset it correctly uses netcdf also for the whole dataset.
Tests run fine, this is the output:
# python netcdf.py
/usr/lib/python2.4/site-packages/GDAL-1.9.0-py2.4-linux-i686.egg/osgeo/gdal.py:80:
DeprecationWarning: gdal.py was placed in a namespace, it is now
available as osgeo.gdal
DeprecationWarning)
TEST: netcdf_1 ... NOTICE: using netcdf version 4.1.3 has_nc2: True
has_nc4: False
success
TEST: netcdf_2 ... success
TEST: netcdf_3 ... success
TEST: netcdf_4 ... success
TEST: netcdf_5 ... success
TEST: netcdf_6 ... success
TEST: netcdf_7 ... success
TEST: netcdf_8 ... success
TEST: netcdf_9 ... success
TEST: netcdf_10 ... success
TEST: netcdf_11 ... success
TEST: netcdf_12 ... success
TEST: netcdf_13 ... success
TEST: netcdf_14 ... success
TEST: netcdf_15 ... success
TEST: netcdf_16 ... skip
TEST: netcdf_17 ... skip
TEST: netcdf_18 ... skip
TEST: netcdf_19 ... skip
TEST: netcdf_20 ... skip
TEST: netcdf_21 ... skip
TEST: netcdf_22 ... skip
TEST: netcdf_23 ... skip
TEST: netcdf_24 ... success
TEST: netcdf_25 ... success
TEST: netcdf_26 ... success
TEST: netcdf_27 ... success
TEST: SetGeoTransform: byte.tif ... success
TEST: SetProjection: byte.tif ... success
TEST: CreateCopy: byte.tif ... success
TEST: Create: byte.tif ... success
TEST: SetNoDataValue: byte.tif ... success
TEST: CreateCopy: byte_signed.tif ... success
TEST: Create: byte_signed.tif ... success
TEST: SetNoDataValue: byte_signed.tif ... success
TEST: CreateCopy: int16.tif ... success
TEST: Create: int16.tif ... success
TEST: SetNoDataValue: int16.tif ... success
TEST: CreateCopy: int32.tif ... success
TEST: Create: int32.tif ... success
TEST: SetNoDataValue: int32.tif ... success
TEST: CreateCopy: float32.tif ... success
TEST: Create: float32.tif ... success
TEST: SetNoDataValue: float32.tif ... success
TEST: CreateCopy: float64.tif ... success
TEST: Create: float64.tif ... success
TEST: SetNoDataValue: float64.tif ... success
Test Script: netcdf
Succeeded: 39
Failed: 0 (0 blew exceptions)
Skipped: 8
Expected fail:0
I will send you the link to download a test dataset off list.
cheers
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
