[gdal-dev] Cannot read NetCDF subdatasets
Etienne Tourigny
etourigny.dev at gmail.com
Mon Jun 25 07:41:08 PDT 2012
For informatioon: the problem was that Paolo was using custom netcdf
libraries and did not add the proper option to configure
--with-netcdf=/usr/local
Etienne
On Wed, Jun 20, 2012 at 5:47 AM, Paolo Corti <pcorti at gmail.com> wrote:
> On Tue, Jun 19, 2012 at 7:48 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> no... unless your system uses the hdf5 driver before the netcdf driver.
>> If the netcdf driver detects a hdf5 file that ends with nc, nc2, nc4
>> or cdf (the common extensions) then it opens it, else it passes it to
>> the hdf5 driver.
>> There is no other way of identifying hdf5 files that are not "netcdf-4" files.
>> There is a test in the autotest suite that tests that the netcdf
>> driver picks up netcdf-4 files but not other hdf5 files. If you do
>> have the autotests installed, try to run the gdrivers/netcdf.py test.
>> Can you send an example file to me?
> The system, when opening the whole dataset uses hdf5 as the default.
> At least, gdalinfo display the list of each subdataset like this:
> Subdatasets:
> SUBDATASET_1_NAME=HDF5:"/effisRisk/Data/Season-2012/Ecmwf/m05/Glb_20120528.nc4"://cf_DangerRisk
> SUBDATASET_1_DESC=[10x640x1280] //cf_DangerRisk (32-bit floating-point)
> SUBDATASET_2_NAME=HDF5:"/effisRisk/Data/Season-2012/Ecmwf/m05/Glb_20120528.nc4"://cf_FWI
> SUBDATASET_2_DESC=[10x640x1280] //cf_FWI (32-bit floating-point)
> When opening a subdatset it uses the netcdf as the default
> If I specify NETCDF:dataset it correctly uses netcdf also for the whole dataset.
> Tests run fine, this is the output:
> # python netcdf.py
> /usr/lib/python2.4/site-packages/GDAL-1.9.0-py2.4-linux-i686.egg/osgeo/gdal.py:80:
> DeprecationWarning: gdal.py was placed in a namespace, it is now
> available as osgeo.gdal
> DeprecationWarning)
> TEST: netcdf_1 ... NOTICE: using netcdf version 4.1.3 has_nc2: True
> has_nc4: False
> success
> TEST: netcdf_2 ... success
> TEST: netcdf_3 ... success
> TEST: netcdf_4 ... success
> TEST: netcdf_5 ... success
> TEST: netcdf_6 ... success
> TEST: netcdf_7 ... success
> TEST: netcdf_8 ... success
> TEST: netcdf_9 ... success
> TEST: netcdf_10 ... success
> TEST: netcdf_11 ... success
> TEST: netcdf_12 ... success
> TEST: netcdf_13 ... success
> TEST: netcdf_14 ... success
> TEST: netcdf_15 ... success
> TEST: netcdf_16 ... skip
> TEST: netcdf_17 ... skip
> TEST: netcdf_18 ... skip
> TEST: netcdf_19 ... skip
> TEST: netcdf_20 ... skip
> TEST: netcdf_21 ... skip
> TEST: netcdf_22 ... skip
> TEST: netcdf_23 ... skip
> TEST: netcdf_24 ... success
> TEST: netcdf_25 ... success
> TEST: netcdf_26 ... success
> TEST: netcdf_27 ... success
> TEST: SetGeoTransform: byte.tif ... success
> TEST: SetProjection: byte.tif ... success
> TEST: CreateCopy: byte.tif ... success
> TEST: Create: byte.tif ... success
> TEST: SetNoDataValue: byte.tif ... success
> TEST: CreateCopy: byte_signed.tif ... success
> TEST: Create: byte_signed.tif ... success
> TEST: SetNoDataValue: byte_signed.tif ... success
> TEST: CreateCopy: int16.tif ... success
> TEST: Create: int16.tif ... success
> TEST: SetNoDataValue: int16.tif ... success
> TEST: CreateCopy: int32.tif ... success
> TEST: Create: int32.tif ... success
> TEST: SetNoDataValue: int32.tif ... success
> TEST: CreateCopy: float32.tif ... success
> TEST: Create: float32.tif ... success
> TEST: SetNoDataValue: float32.tif ... success
> TEST: CreateCopy: float64.tif ... success
> TEST: Create: float64.tif ... success
> TEST: SetNoDataValue: float64.tif ... success
> Test Script: netcdf
> Succeeded: 39
> Failed: 0 (0 blew exceptions)
> Skipped: 8
> Expected fail:0
> I will send you the link to download a test dataset off list.
> cheers
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
