[gdal-dev] Errors with ogr2ogr and DXF files (ASCII and BIN)
Mac Wind
macwind2 at gmail.com
Wed Jun 27 06:52:19 PDT 2012
Hi.
Using OGR, I'm trying to reproject a DXF file. I'm using ogr2ogr, but
I get two type of errors depending if I start with a BIN DXF or an
ASCII DXF file.
With BIN DXF:
ogr2ogr -s_srs 27492.prj -t_srs 4326.prj myfile_WGS84.dxf myfile_BIN12.dxf
I get this error message:
FAILURE:
Unable to open datasource `myfile_BIN12.dxf' with the following drivers.
[+ the list of installed drivers, included DXF]
With ASCII DXF
ogr2ogr -s_srs 27492.prj -t_srs 4326.prj myfile_WGS84.dxf myfile_ASCII12.dxf
FAILED: Layer entities already exists, and -append not specified.
Consider using -append, or -overwrite.
ERROR 1: Terminating translation prematurely after failed
translation of layer entities (use -skipfailures to skip errors)
(effectively, 'entities' does exist, but this the expected situation, right?)
I don't know what I am doing wrong. I tried with different BIN and
ASCII versions (R13, R14, 2007, 2010), with the same errors.
Thank you very much in advance.
