[gdal-dev] Errors with ogr2ogr and DXF files (ASCII and BIN)
Jean-Claude Repetto jrepetto at free.fr
Wed Jun 27 07:09:50 PDT 2012
Le 27/06/2012 15:52, Mac Wind a écrit :
> With ASCII DXF
> ogr2ogr -s_srs 27492.prj -t_srs 4326.prj myfile_WGS84.dxf myfile_ASCII12.dxf
> I get this error message:
> FAILED: Layer entities already exists, and -append not specified.
>          Consider using -append, or -overwrite.
Try to remove the output file before executing the ogr2ogr command.
BTW, you have forgotten the -f "DXF" parameter.
Jean-Claude
