[gdal-dev] drawing line using OGR and mysql in mapserver
Murat Beyhan beyhan at deprem.gov.tr
Thu Mar 1 02:18:40 EST 2012
Chaitanya,
I have had a progress about VRT data access
but I afraid something wrong in mapserver .map file.
here is the test.vrt file and I use in map file with connection ogr
functionality. :
<OGRVRTDataSource>
<OGRVRTLayer name="dynamic">
<SrcDataSource>MYSQL:dynamic,user=root,password=mysql_passwd,host=localhost,port=3306,tables=lineview</SrcDataSource>
<SrcSql>select eq_id, geom from lineview</SrcSql>
<GeometryType>wkbLineString</GeometryType>
<GeometryField encoding="WKT" field="geom"/>
</OGRVRTLayer>
</OGRVRTDataSource>
then the command
[murat at localhost stations]$ ogrinfo -ro -al test.vrt
INFO: Open of `test.vrt'
      using driver `VRT' successful.
Layer name: dynamic
Geometry: Line String
Feature Count: 2
Layer SRS WKT:
(unknown)
eq_id: String (42.0)
geom: Real (23.0)
OGRFeature(dynamic):0
  eq_id (String) = 20111023101120
  geom (Real) =                     164
OGRFeature(dynamic):1
  eq_id (String) = 20100308023229
  geom (Real) =                     163
it works now but mapserver gives an error as follows:
Server error!
The server encountered an internal error and was unable to complete your
request.
Error message:
Premature end of script headers: mapserv
If you think this is a server error, please contact the webmaster.
Error 500
10.14.0.67
Apache/2.2.14 (Mandriva Linux/PREFORK-1.6mdv2010.0)
I think I will solve it with your help.
Many thanks
Murat
On Thu, 2012-03-01 at 09:22 +0530, Chaitanya kumar CH wrote:
> Murat,
> You should check MySQL's SQL syntax to concatenate strings and
> decimals to produce a string.
> On Wednesday, February 29, 2012, Murat Beyhan <beyhan at deprem.gov.tr>
> wrote:
> > Chaitanya,
> > here is the structure of table on database
> > sfault :
> > eq_id varchar(14)
> > lat1  decimal(7,4)
> > lon1  decimal(7,4)
> > lat2  decimal(7,4)
> > lon2  decimal(7,4)
> > lineview :
> > eq_id varchar(14)
> > geom  double
> > it seams geom as double
> > I thing it should be geometry isn't it?
> > may be  I have to change structure of lineview by changing following
> > Roberts' suggestion to create view on database
> >  create view lineview as select eq_id, "LINESTRING(" + lon1 + " " +
> lat1
> >  + "," + lon2 + " " + lat2 + ")" as geom from sfault
> > but I'm not sure for the line.
> > VTR for points, I have tested and works well
> > but for line still could not achieved yet, please give me another
> idea.
> > here is test.vrt file
> > <OGRVRTDataSource>
> > <OGRVRTLayer name="sta">
> <SrcDataSource>MYSQL:stations,user=root,password=mysql_passwd,host=localhost,port=3306,tables=sta</SrcDataSource>
> > <SrcSQL>SELECT sta_id as name,type,latitude,longitude from sta where
> > type like "%SMACH%"</SrcSQL>
> > <GeometryType>wkbPoint</GeometryType>
> > <GeometryField encoding="PointFromColumns" x="longitude"
> y="latitude"/>
> > </OGRVRTLayer>
> > </OGRVRTDataSource>
> > and following code gives successful result as you see
> > INFO: Open of `test.vrt' using driver `VRT' successful.
> > Layer name: sta
> > Geometry: Point
> > Feature Count: 12
> > Layer SRS WKT:
> > (unknown)
> > type: String (24.0)
> > latitude: Real (5.4)
> > longitude: Real (5.4)
> > OGRFeature(sta):0
> >  name (String) = 0617
> >  type (String) = SMACH
> >  latitude (Real) = 40.4569
> >  longitude (Real) = 32.6319
> >  POINT (32.631900000000002 40.456899999999997)
> > OGRFeature(sta):1
> >  name (String) = 0618
> >  latitude (Real) = 40.4798
> >  longitude (Real) = 32.4555
> >  POINT (32.4555 40.479799999999997)
> > As you see this works well.
> > I hope you can catch point what is wrong or lack of on my works....
> > Thanks again
> > On Tue, 2012-02-28 at 18:08 +0530, Chaitanya kumar CH wrote:
> >> Murat,
> >> I see that your view,  lineview, doesn't give the expected geometry
> >> type with ogrinfo. It is showing the datatype as Real. Check if the
> >> datatype of geom is actually string/text.
> >> On Tue, Feb 28, 2012 at 12:49 PM, Murat Beyhan
> >> wrote:
> >>         Chaitanya,
> >>         Map file which is try to draw line as follows
> >>         are there any problem on the code
> >>          LAYER
> >>          NAME sfault1
> >>          CONNECTIONTYPE OGR
> >>          CONNECTION '<OGRVRTDataSource>
> >>          <OGRVRTLayer name="lineview">
> <SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
> >>          <SrcLayer>lineview</SrcLayer>
> >>          <LayerSRS>WGS84</LayerSRS>
> >>          <FID>eq_id</FID>
> >>          </OGRVRTLayer>
> >>          </OGRVRTDataSource>'
> >>          DATA sfault1
> >>          STATUS on
> >>          TYPE line
> >>          CLASS
> >>          NAME "Source Fault"
> >>          SYMBOL "cline"
> >>           SIZE 3
> >>          COLOR  0 0 255
> >>          END
> >>          END
> >>         ogrinfo
> >>         sfault -summary
> >>         INFO: Open of
> `MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306'
> >>              using driver `MySQL' successful.
> >>         Layer name: sfault
> >>         Geometry: None
> >>         Feature Count: 1
> >>         Layer SRS WKT:
> >>         (unknown)
> >>         eq_id: String (14.0)
> >>         lat1: Real (7.4)
> >>         lon1: Real (7.4)
> >>         lat2: Real (7.4)
> >>         lon2: Real (7.4)
> >>         **************linewiew created by following sql
> >>         statement:*************
> >>         " " + lat1
> >>         then
> >>         [murat at localhost ~]$ ogrinfo
> >>         lineview -summary
> >>         INFO: Open of
> >>         Layer name: lineview
> >>         Geometry: None
> >>         Feature Count: 1
> >>         Layer SRS WKT:
> >>         (unknown)
> >>         geom: Real (0.0)
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Afet ve Acil Durum Yönetimi Başkanlığı
Deprem Dairesi Başkanlığı
Eskişehir Yolu 12. Km.
Lodumlu/ANKARA
Tel: 312 2872680-1556
email:beyhan at deprem.gov.tr
