[gdal-dev] drawing line using OGR and mysql in mapserver
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Mar 1 04:10:24 EST 2012
Murat,
It's not working. the geom field should not be 'Real'. It should be
'String'. Try something else other than the '+' operator in the SQL syntax
to create the geom field in the view.
On Thu, Mar 1, 2012 at 12:48 PM, Murat Beyhan <beyhan at deprem.gov.tr> wrote:
> Chaitanya,
> I have had a progress about VRT data access
> but I afraid something wrong in mapserver .map file.
> here is the test.vrt file and I use in map file with connection ogr
> functionality. :
> <OGRVRTDataSource>
> <OGRVRTLayer name="dynamic">
> <SrcDataSource>MYSQL:dynamic,user=root,password=mysql_passwd,host=localhost,port=3306,tables=lineview</SrcDataSource>
> <SrcSql>select eq_id, geom from lineview</SrcSql>
> <GeometryType>wkbLineString</GeometryType>
> <GeometryField encoding="WKT" field="geom"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> then the command
> [murat at localhost stations]$ ogrinfo -ro -al test.vrt
> INFO: Open of `test.vrt'
>      using driver `VRT' successful.
> Layer name: dynamic
> Geometry: Line String
> Feature Count: 2
> Layer SRS WKT:
> (unknown)
> eq_id: String (42.0)
> geom: Real (23.0)
> OGRFeature(dynamic):0
>  eq_id (String) = 20111023101120
>  geom (Real) =                     164
> OGRFeature(dynamic):1
>  eq_id (String) = 20100308023229
>  geom (Real) =                     163
> it works now but mapserver gives an error as follows:
> Server error!
> The server encountered an internal error and was unable to complete your
> request.
> Error message:
> Premature end of script headers: mapserv
> If you think this is a server error, please contact the webmaster.
> Error 500
> 10.14.0.67
> Apache/2.2.14 (Mandriva Linux/PREFORK-1.6mdv2010.0)
> I think I will solve it with your help.
> Many thanks
> Murat
> On Thu, 2012-03-01 at 09:22 +0530, Chaitanya kumar CH wrote:
> > Murat,
> > You should check MySQL's SQL syntax to concatenate strings and
> > decimals to produce a string.
> > On Wednesday, February 29, 2012, Murat Beyhan <beyhan at deprem.gov.tr>
> > wrote:
> > > Chaitanya,
> > > here is the structure of table on database
> > > sfault :
> > > eq_id varchar(14)
> > > lat1  decimal(7,4)
> > > lon1  decimal(7,4)
> > > lat2  decimal(7,4)
> > > lon2  decimal(7,4)
> > > lineview :
> > > eq_id varchar(14)
> > > geom  double
> > > it seams geom as double
> > > I thing it should be geometry isn't it?
> > > may be  I have to change structure of lineview by changing following
> > > Roberts' suggestion to create view on database
> > >  create view lineview as select eq_id, "LINESTRING(" + lon1 + " " +
> > lat1
> > >  + "," + lon2 + " " + lat2 + ")" as geom from sfault
> > > but I'm not sure for the line.
> > > VTR for points, I have tested and works well
> > > but for line still could not achieved yet, please give me another
> > idea.
> > > here is test.vrt file
> > > <OGRVRTDataSource>
> > > <OGRVRTLayer name="sta">
> <SrcDataSource>MYSQL:stations,user=root,password=mysql_passwd,host=localhost,port=3306,tables=sta</SrcDataSource>
> > > <SrcSQL>SELECT sta_id as name,type,latitude,longitude from sta where
> > > type like "%SMACH%"</SrcSQL>
> > > <GeometryType>wkbPoint</GeometryType>
> > > <GeometryField encoding="PointFromColumns" x="longitude"
> > y="latitude"/>
> > > </OGRVRTLayer>
> > > </OGRVRTDataSource>
> > > and following code gives successful result as you see
> > > INFO: Open of `test.vrt' using driver `VRT' successful.
> > > Layer name: sta
> > > Geometry: Point
> > > Feature Count: 12
> > > Layer SRS WKT:
> > > (unknown)
> > > type: String (24.0)
> > > latitude: Real (5.4)
> > > longitude: Real (5.4)
> > > OGRFeature(sta):0
> > >  name (String) = 0617
> > >  type (String) = SMACH
> > >  latitude (Real) = 40.4569
> > >  longitude (Real) = 32.6319
> > >  POINT (32.631900000000002 40.456899999999997)
> > > OGRFeature(sta):1
> > >  name (String) = 0618
> > >  latitude (Real) = 40.4798
> > >  longitude (Real) = 32.4555
> > >  POINT (32.4555 40.479799999999997)
> > > As you see this works well.
> > > I hope you can catch point what is wrong or lack of on my works....
> > > Thanks again
> > > On Tue, 2012-02-28 at 18:08 +0530, Chaitanya kumar CH wrote:
> > >> Murat,
> > >> I see that your view,  lineview, doesn't give the expected geometry
> > >> type with ogrinfo. It is showing the datatype as Real. Check if the
> > >> datatype of geom is actually string/text.
> > >> On Tue, Feb 28, 2012 at 12:49 PM, Murat Beyhan
> > >> wrote:
> > >>         Chaitanya,
> > >>         Map file which is try to draw line as follows
> > >>         are there any problem on the code
> > >>          LAYER
> > >>          NAME sfault1
> > >>          CONNECTIONTYPE OGR
> > >>          CONNECTION '<OGRVRTDataSource>
> > >>          <OGRVRTLayer name="lineview">
> <SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
> > >>          <SrcLayer>lineview</SrcLayer>
> > >>          <LayerSRS>WGS84</LayerSRS>
> > >>          <FID>eq_id</FID>
> > >>          </OGRVRTLayer>
> > >>          </OGRVRTDataSource>'
> > >>          DATA sfault1
> > >>          STATUS on
> > >>          TYPE line
> > >>          CLASS
> > >>          NAME "Source Fault"
> > >>          SYMBOL "cline"
> > >>           SIZE 3
> > >>          COLOR  0 0 255
> > >>          END
> > >>          END
> > >>         ogrinfo
> > >>         sfault -summary
> > >>         INFO: Open of
> > `MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306'
> > >>              using driver `MySQL' successful.
> > >>         Layer name: sfault
> > >>         Geometry: None
> > >>         Feature Count: 1
> > >>         Layer SRS WKT:
> > >>         (unknown)
> > >>         eq_id: String (14.0)
> > >>         lat1: Real (7.4)
> > >>         lon1: Real (7.4)
> > >>         lat2: Real (7.4)
> > >>         lon2: Real (7.4)
> > >>         **************linewiew created by following sql
> > >>         statement:*************
> > >>         " " + lat1
> > >>         then
> > >>         [murat at localhost ~]$ ogrinfo
> > >>         lineview -summary
> > >>         INFO: Open of
> > >>         Layer name: lineview
> > >>         Geometry: None
> > >>         Feature Count: 1
> > >>         Layer SRS WKT:
> > >>         (unknown)
> > >>         geom: Real (0.0)
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
> Murat BEYHAN
> Jeofizik Y.Müh.
> T.C. Başbakanlık
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120301/ad897bf5/attachment-0001.html
