[gdal-dev] GDAL1.8.1 PCIDSK linked files ticket 21513
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 1 17:26:20 EST 2012
Shawn,
I believe 1.8 does not contain lots of improvements including some
kinds of linked files - for instance as represented by:
http://trac.osgeo.org/gdal/changeset/21920
http://trac.osgeo.org/gdal/changeset/21921
I would suggest you try with GDAL 1.9.0. Back porting bits of the
pcidsk sdk into 1.8 is likely to be problematic.
Best regards,
Frank
On Thu, Mar 1, 2012 at 2:11 PM, Shawn Gong <SGONG at mdacorporation.com> wrote:
> Hi list,
> I am using GDAL1.8.1 and gdal.Open() failed on some PCIDSK linked files
> The error message is “ERROR 4: `LNK=1024File requires a newer PCIDSK file reader to read' does not exist in the file system, and is not recognised as a supported dataset name."
> I have seen the ticket on http://trac.osgeo.org/gdal/changeset/21513
> Is this ticket closed or still an issue in 1.8.1?
> Is this fixed for GDAL 1.9.0 or other version(s)?
> Thanks,
> Shawn_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
