[gdal-dev] Wrong resolution info from multitable rasterlite
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Mar 13 03:50:17 EDT 2012
See what happened when I took two tiffs with different resolutions
This one
suomi45m_tm35fin.tif
Origin = (-70042.000000000000000,7903802.000000000000000)
Pixel Size = (200.000000000000000,-200.000000000000000)
and another
gdalinfo suomi1m_tm35fin.tif
Origin = (19970.000000000000000,7785300.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
I converted them into the same rasterlite DB with these four commands:
gdal_translate -of rasterlite -a_srs epsg:3067 suomi45m_tm35fin.tif
rasterlite:multitable.sqlite,table=suomi45m
gdal_translate -of rasterlite -a_srs epsg:3067 suomi1m_tm35fin.tif
rasterlite:multitable.sqlite,table=suomi1m
gdaladdo rasterlite:multitable.sqlite,table=suomi45m 2 4 8 16
gdaladdo rasterlite:multitable.sqlite,table=suomi1m 2 4 8 16
Now gdalinfo reports that both of these rasterlite tables have
a pixel size of 200 m
gdalinfo rasterlite:mmlrasterit_2011.sqlite,table=suomi45m
gdalinfo rasterlite:mmlrasterit_2011.sqlite,table=suomi1m
Quantum GIS is placing the map that actually has 100 m pixels in a
wrong scale into a project. However, I am not sure if this pure
GDAL error because Spatialite-gis seems to make the same
error. I can see correct values in the pixel_x_size x and
pixel_y_size columns in the corresponding raster metadata tables.
Everything works as expected if I convert images separately into
two single-table databases.
-Jukka Rahkonen-
