[gdal-dev] caching in gdal
Etienne Tourigny etourigny.dev at gmail.com
Tue Mar 13 08:32:00 EDT 2012
Akshay,
Caching is done independently for each opened dataset, as long as
total caching does not exceed GDAL_CACHEMAX.
You can control the size of the cache with the GDAL_CACHEMAX config
option, see the following wiki pages
http://trac.osgeo.org/gdal/wiki/ConfigOptions
http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp
GDALRasterBand::RasterIO() takes care of caching internally so you
don't have to worry about it
GDALRasterBand::ReadBlock() is more efficient but also less flexible.
See the various ReadBlock/RasterIO/GetLockedBlockRef functions in
http://www.gdal.org/classGDALRasterBand.html
Perhaps there is a more descriptive reference somewhere?
Etienne
On Tue, Mar 13, 2012 at 2:11 AM, akshay gupta <akshaygupta202 at gmail.com> wrote:
> Hi all,
> How exactly does caching work in gdal. If I have 2 or more images opened
> simultaneously in gdal, does gdal consider the tiles(or scanlines) belonging
> to different images separately or does it keeps a common set, can any body
> explain how it is done in gdal.
> Thanks and regards,
> Akshay
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
