[gdal-dev] compiling with FileGeodb API 1.2
Kyle Shannon
KShannon at gcs-research.com
Thu Mar 15 18:54:18 EDT 2012
I didn't reconfigure, just dumped the new libs in place of the old and it linked. I get the same results as you now.
kss
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, March 15, 2012 4:39 PM
To: gdal-dev at lists.osgeo.org
Cc: Kyle Shannon; Stefano Iacovella
Subject: Re: [gdal-dev] compiling with FileGeodb API 1.2
Le jeudi 15 mars 2012 23:24:22, Kyle Shannon a écrit :
> Stefano,
> I just built from the trunk with filegdb support and had no issues. I
> would make sure the 1.1 version is off your system and not anywhere
> configure could find it, then try again.
Kyle,
I've just experienced the same issue as Stefano's. I'm not clear why it works for you, but ESRI did actually renamed the unix support lib, and GDAL's configure needs to be updated. Sigh sigh sigh....
Stefano, would you mind opening a ticket about that ?
Even
