[gdal-dev] compiling with FileGeodb API 1.2
Stefano Iacovella
stefano.iacovella at gmail.com
Fri Mar 16 17:46:53 EDT 2012
I opened a ticket for the issue:
http://trac.osgeo.org/gdal/ticket/4570
Best regards
Stefano
2012/3/15 Even Rouault <even.rouault at mines-paris.org>:
> Le jeudi 15 mars 2012 23:24:22, Kyle Shannon a écrit :
>> Stefano,
>> I just built from the trunk with filegdb support and had no issues. I
>> would make sure the 1.1 version is off your system and not anywhere
>> configure could find it, then try again.
> Kyle,
> I've just experienced the same issue as Stefano's. I'm not clear why it works
> for you, but ESRI did actually renamed the unix support lib, and GDAL's
> configure needs to be updated. Sigh sigh sigh....
> Stefano, would you mind opening a ticket about that ?
> Even
