[gdal-dev] Performance problems
Even Rouault
even.rouault at mines-paris.org
Sat Mar 17 07:58:08 EDT 2012
Le samedi 17 mars 2012 08:41:20, Ari Jolma a écrit :
> Folks,
> This is a broader question, but maybe somebody can help. I've set up a
> simple WFS based on GDAL with Perl bindings. The service loads a dataset
> from PostGIS copies it into a GML dataset in memory and serves it from
> there.
Instead of storing a GML dataset in memory, it might help to pipe it directly
to standard output (using /vsistdout/ filename). That should consume very few
memory.
> Nice clean solution and works well. Then I tried to use it in a
> student exercise. The server (RHEL5, Apache 2.2.3) I use for this
> purpose is not very resourceful and WFS set up this way easily uses a
> lot of memory. Thus, when 10 students all made requests at the same
> time, all memory was used (apache logs have "Out of memory!" - I'm not
> sure where this comes from) and the service did not work (QGIS reacted
> by turning gray ad had to be killed).
> Is there a way to refuse starting a service if there are not enough
> resources? This would lead to a much nicer response than gray QGIS.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
