[gdal-dev] gdal_translate: invalid tile byte error
Frank Warmerdam
warmerdam at pobox.com
Sat Mar 17 18:24:54 EDT 2012
On 12-03-17 01:15 PM, Andrea Peri wrote:
> Hi,
> I'm try-ing to create a set of tiff tiled with internal overviews from some
> geotiffs, using this call:
> gdal_translate -ot Byte -of GTiff -co TILED=YES -co TFW=YES -co
> COPY_SRC_OVERVIEWS=YES -co TIFF_USE_OVR=TRUE -co PROFILE=BASELINE -co TFW=YES
> input.tif output.tif
> meanwhile it run , it report many errors like these:
> ERROR 1: 248040_2010.tif:0: Invalid tile byte count, tile 2323
> ERROR 1: 248040_2010.tif:0: Invalid tile byte count, tile 2324
> ERROR 1: 248040_2010.tif:0: Invalid tile byte count, tile 2325
> ERROR 1: 248040_2010.tif:0: Invalid tile byte count, tile 2326
> ERROR 1: 248040_2010.tif:0: Invalid tile byte count, tile 2327
> I don't know what this mean and what can I do to avoid this error.
> Is gdal_translate the right tool to create a tiff-tile ?
Andrea,
Sometimes the libtiff, the TIFF library used by GDAL does not work properly
when creating files with compressed overview tiles if you are not using a
very recent version of libtiff. Is it possible you are using a GDAL built
with libtiff 3.9.x instead of the internal libtiff or libtiff 4.0.x?
Would it meet your needs to copy the base image (without the -co
COPY_SRC_OVERVIEWS flag) and then regenerate the overviews with gdaladdo?
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush | Geospatial Software Developer
