[gdal-dev] Error when compiling GDAL trunk
Even Rouault
even.rouault at mines-paris.org
Thu Mar 22 16:57:58 EDT 2012
Le jeudi 22 mars 2012 21:54:39, Jean-Claude Repetto a écrit :
> On 03/22/12 20:55, Even Rouault wrote:
> > I'm a bit hesitant to apply that for now. Hopefully Gentoo will revert
> > their change under user pressure. Please complain loudly in the ticket
> It seems they have chosen the option to patch all the packages that are
> using the OF macro.
> For GDAL, see : https://bugs.gentoo.org/show_bug.cgi?id=383569
> The (small) problem is that vanilla versions of GDAL won't compile on
> Gentoo systems anymore, but it shouldn't affect a lot of people.
Oh well, if you can confirm the patch works, I'll end up commiting it. It isn't
too invasive.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
