[gdal-dev] vsicurl
Kyle Shannon
kyle at pobox.com
Fri Mar 23 16:57:11 EDT 2012
Can the VSI*L support be added to drivers that use a third party API
similar to the way it is done in the geotiff driver? Would that be a good
reference to add support to other drivers?
On Fri, Mar 23, 2012 at 14:33, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Kyle,
> You need to have built GDAL with curl support and the drivers has do
> do all file access through VSI*L functions.
> Best regards,
> Frank
> On Fri, Mar 23, 2012 at 1:31 PM, Kyle Shannon <kyle at pobox.com> wrote:
> > What are the requirements for using the vsicurl handler for accessing
> files?
> > Do drivers have to implement anything special do have curl support?
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/f23f9d5f/attachment.html
