[gdal-dev] vsicurl
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 23 17:06:13 EDT 2012
On Fri, Mar 23, 2012 at 1:57 PM, Kyle Shannon <kyle at pobox.com> wrote:
> Can the VSI*L support be added to drivers that use a third party API similar
> to the way it is done in the geotiff driver? Would that be a good reference
> to add support to other drivers?
Kyle,
There are a number of external libraries where we are able to hook
the IO functions for that sublibrary and route things through VSI*L.
The GeotTIFF, MrSID, ECW and Shapefile drivers are all examples
of this I believe. How it exactly works depends on the IO hooking
mechanisms provided by the external library. Some provide no
usable mechanism.
Best regards,
Frank
> On Fri, Mar 23, 2012 at 14:33, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Kyle,
>> You need to have built GDAL with curl support and the drivers has do
>> do all file access through VSI*L functions.
>> Best regards,
>> Frank
>> On Fri, Mar 23, 2012 at 1:31 PM, Kyle Shannon <kyle at pobox.com> wrote:
>> > What are the requirements for using the vsicurl handler for accessing
>> > files?
>> > Do drivers have to implement anything special do have curl support?
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Software Developer
