[gdal-dev] vsicurl
Kyle Shannon
kyle at pobox.com
Fri Mar 23 17:07:10 EDT 2012
Thanks.
kss
On Fri, Mar 23, 2012 at 15:06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On Fri, Mar 23, 2012 at 1:57 PM, Kyle Shannon <kyle at pobox.com> wrote:
> > Can the VSI*L support be added to drivers that use a third party API
> similar
> > to the way it is done in the geotiff driver? Would that be a good
> reference
> > to add support to other drivers?
> Kyle,
> There are a number of external libraries where we are able to hook
> the IO functions for that sublibrary and route things through VSI*L.
> The GeotTIFF, MrSID, ECW and Shapefile drivers are all examples
> of this I believe. How it exactly works depends on the IO hooking
> mechanisms provided by the external library. Some provide no
> usable mechanism.
> Best regards,
> Frank
> > On Fri, Mar 23, 2012 at 14:33, Frank Warmerdam <warmerdam at pobox.com>
> wrote:
> >> Kyle,
> >> You need to have built GDAL with curl support and the drivers has do
> >> do all file access through VSI*L functions.
> >> Best regards,
> >> Frank
> >> On Fri, Mar 23, 2012 at 1:31 PM, Kyle Shannon <kyle at pobox.com> wrote:
> >> > What are the requirements for using the vsicurl handler for accessing
> >> > files?
> >> > Do drivers have to implement anything special do have curl support?
> >> > _______________________________________________
> >> > gdal-dev mailing list
> >> > gdal-dev at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> I set the clouds in motion - turn up | Frank Warmerdam,
> >> light and sound - activate the windows | http://pobox.com/~warmerdam
> >> and watch the world go round - Rush | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/069058c6/attachment-0001.html
