[gdal-dev] Ogr2OGR for GeoJSON fails on windows 7
Mateusz Loskot mateusz at loskot.net
Fri Mar 30 05:18:28 EDT 2012
On 30 March 2012 01:35, Eli Adam <eadam at co.lincoln.or.us> wrote:
> Vivek,
>> My bad , i did typo in writing here. I have written correctly as GeoJSON for
>> conversion.
> Are you saying that you typed it correctly on the command line and it
> still doesn't work?
I'm fairly sure he typed it correctly.
The error message he got is spelled correclty:
"Failed to create geoJSON datasource"
Either folder rights are not right, or dataset translation fails.
If the latter, sample data + ticket would be appreciated.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
