[gdal-dev] Ogr2OGR for GeoJSON fails on windows 7
Vivek Dey
vivekde at gmail.com
Fri Mar 30 10:31:24 EDT 2012
Hello
Thank you all for helping me out.
The error was because of the write permission in the directory.
I changed the directory and it works well.
Thanks Chaitanya and everybody else.
Vivek
On Fri, Mar 30, 2012 at 3:18 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 30 March 2012 01:35, Eli Adam <eadam at co.lincoln.or.us> wrote:
> > Vivek,
> >> My bad , i did typo in writing here. I have written correctly as
> GeoJSON for
> >> conversion.
> > Are you saying that you typed it correctly on the command line and it
> > still doesn't work?
> I'm fairly sure he typed it correctly.
> The error message he got is spelled correclty:
> "Failed to create geoJSON datasource"
> Either folder rights are not right, or dataset translation fails.
> If the latter, sample data + ticket would be appreciated.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120330/50c11f21/attachment.html
