[gdal-dev] Re: gdal_translate waits at the end of operation
    Etienne Tourigny
    etourigny.dev at gmail.com
    Wed May  9 20:28:35 EDT 2012
do you get the same problem when converting to another format (say
gtiff) or using other files as input?
Etienne
On Wed, May 9, 2012 at 9:17 PM, kaarigar <kaarigar at gmail.com> wrote:
> I can convert a single image to XYZ from command line. And can also convert
> multiple images to command line via batch file - if I press CTRL-C after the
> conversion for one file is 100% done - it will continue to the next file.
> There are no errors or warnings. The conversion to XYZ is successful. I have
> also tried this on Windows 7 32bit - and found the same problem there too.
> Kyle Shannon-3 wrote
>> More questions?  Can you convert one image into an xyz?  It sounds like
>> you
>> can.  Are there no errors or warnings?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964362.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
