[gdal-dev] Re: gdal_translate waits at the end of operation
kaarigar
kaarigar at gmail.com
Thu May 10 02:16:15 EDT 2012
Thanks for the suggestion. I tried to convert GeoTIFF to jpg - and there
wasn't the problem. Then I tried to convert a small GeoTIFF (20 mb) to XYZ -
it still waited for some time (~10 secs) after displaying the "Done."
message. I think what is happening is that I was converting a set of very
large files (each ~300 mb) - and that makes gdal_translate wait for quite
some time after the "Done." message. This time I waited long enough and the
gdal_translate process was able to continue to the next file in the batch
file. Still I am not sure why gdal_translate has to wait at the end of the
conversion.
Thanks to everyone for help!
Etienne Tourigny-3 wrote
> do you get the same problem when converting to another format (say
> gtiff) or using other files as input?
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964870.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
