[gdal-dev] GDAL with GEOS static
Jorge Izquierdo Ciges jorizci at gmail.com
Thu May 10 08:22:30 EDT 2012
Hello and good day.
 I've been trying to get GDAL compiled with GEOS static in Linux with the
./configure, but i've seen in the config.log that it's checked against the
*.so. Also i've not found an option to static link GEOS as it can be with
proj4. Can it be linked statically? and if it's affirmative how should I
proceed?
Thanks in advance.
J.Izquierdo
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120510/2c09fa43/attachment.html
