[gdal-dev] python gdal.gdal.ReprojectImage not masking NoData in
signed byte geotifs
Colin Talbert
talbertc at usgs.gov
Fri May 11 12:29:03 EDT 2012
Hello all,
I'm running into an issue reprojecting a single band geotif in python.
My code works fine on pixel types other than signed byte. What I'm seeing
is that the interpolation that includes a nodata pixel uses the literal
nodata value (-128 is the nodata but I think this is being interpreted as
128). In my example I have a grid with values between 0 and 60 and areas
of
nodata. Pixels bordering the nodata areas have values up to 126 in the
output. I've also tried to recreate this process using gdalwarp and I
think I'm getting the same problem.
Thanks for any help or projections. FYI I'm on GDAL 1.8
Attached are the small test files I'm using. BigSage.tif is the input,
template2.tif has the projection info and extent I'm using for the output,
output.tif is what I'm getting.
http://osgeo-org.1560.n6.nabble.com/file/n4967005/BigSage.tif BigSage.tif
http://osgeo-org.1560.n6.nabble.com/file/n4967005/template2.tif
template2.tif
http://osgeo-org.1560.n6.nabble.com/file/n4967005/output.tif
output.tif
Below is a striped down version of my code:
tifDriver = gdal.GetDriverByName("GTiff")
tmpOutDataset = tifDriver.Create(tmpOutput, width, height, 1,
gdal.GDT_Byte,
["PIXELTYPE=SIGNEDBYTE"])
#omited code to set cell size, geotransform, NoData, projection
tmpOutDataset.GetRasterBand(1).PixelType = "SIGNEDBYTE"
tmpOutDataset.GetRasterBand(1).SetMetadata({'PIXELTYPE': 'SIGNEDBYTE'},
'IMAGE_STRUCTURE')
err = gdal.ReprojectImage(srcDs, tmpOutDataset, sourcesrs.ExportToWkt(),
templatesrs.ExportToWkt(),
gdal.GRA_Bilinear)
View this message in context:
http://osgeo-org.1560.n6.nabble.com/python-gdal-gdal-ReprojectImage-not-masking-NoData-in-signed-byte-geotifs-tp4967005.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
Colin Talbert
GIS Specialist
US Geological Survey - Fort Collins Science Center
2150 Centre Ave. Bldg. C
Fort Collins, CO 80526
(970) 226-9425
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120511/47e8ead5/attachment.html
