[gdal-dev] troubles building trunk on OSX + Xcode 4.3
Joaquim Luis
jluis at ualg.pt
Wed May 16 11:40:56 EDT 2012
On 16-05-2012 15:12, William Kyngesburye wrote:
> On May 16, 2012, at 9:08 AM, William Kyngesburye wrote:
>> On May 16, 2012, at 8:50 AM, William Kyngesburye wrote:
>>>> I didn't mentioned explicitly but I did a svn update so the code should be very close to what's in 1.9.1rc
>>>> Anyone building the release candidate on OSX with XCode 4.3.2 successfully?
>>>> Joaquim
>>> 1.9.1rc compiles with no problems (quick-n-dirty, no extras).
>>> I just noticed something else, but I don't know if it's a problem - your libtool command has a "--tag=LD" flag in it, mine doesn't not. You also get that message about ignoring unknown tag, and I wonder if it somehow confuses libtool so that it drops the g++. What is your configure command?
>> Wait, I found the problem, nothing to do with your configure.
>> In trunk, --tag=LD was added to GDALMake.opt.in, but it's not in 1.9.1rc1. When I added that flag to 1.9.1rc, it failed the same as for you. I'll reopen the bug that prompted adding that flag.
> Too hasty, bug is still open, and it looks like unresolved, at least in trunk.
Thanks William for digging into this.
The "--tag=LD" warning caught my eye and that was why I included it in
the pasted text just in case, but it meant nothing to me. So now I
removed the LD tag and all built well again.
Joaquim
