[gdal-dev] troubles building trunk on OSX + Xcode 4.3
William Kyngesburye
woklist at kyngchaos.com
Wed May 16 10:12:34 EDT 2012
On May 16, 2012, at 9:08 AM, William Kyngesburye wrote:
> On May 16, 2012, at 8:50 AM, William Kyngesburye wrote:
>>> I didn't mentioned explicitly but I did a svn update so the code should be very close to what's in 1.9.1rc
>>> Anyone building the release candidate on OSX with XCode 4.3.2 successfully?
>>> Joaquim
>> 1.9.1rc compiles with no problems (quick-n-dirty, no extras).
>> I just noticed something else, but I don't know if it's a problem - your libtool command has a "--tag=LD" flag in it, mine doesn't not. You also get that message about ignoring unknown tag, and I wonder if it somehow confuses libtool so that it drops the g++. What is your configure command?
> Wait, I found the problem, nothing to do with your configure.
> In trunk, --tag=LD was added to GDALMake.opt.in, but it's not in 1.9.1rc1. When I added that flag to 1.9.1rc, it failed the same as for you. I'll reopen the bug that prompted adding that flag.
Too hasty, bug is still open, and it looks like unresolved, at least in trunk.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
