[gdal-dev] Re: georeference and project a jpeg
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri May 25 04:54:23 EDT 2012
jdmorgan <jdmorgan <at> unca.edu> writes:
> Hello,
I am attempting to georeference and project a
jpeg image
using only gdal tool. I
have georeferenced
the jpeg using the following command:
gdal_translate
-a_srs EPSG:102719 -of HFA -gcp 0.0 0.0
-82.5586187839508 35.59414007259327 -gcp 0.0 410.0
-82.55858659744263
35.5937998255945 -gcp 520.0 0.0 -82.55741715431213
35.594340730401775 -gcp
520.0 410.0 -82.55728840827942 35.5940266570877
NCDCLogo.jpg NCDCLogo.img
Derek
I made a test with some holiday picture jpeg and this way it works for me.
Step one
gdal_translate -of GTiff -gcp 0 0 -82.5586187839508 35.59414007259327
-gcp 0 410
-82.55858659744263 35.5937998255945 -gcp 520 0 -82.55741715431213
35.594340730401775 -gcp 520 410 -82.55728840827942 35.5940266570877
test_temp.tif
Step two
gdalwarp -s_srs epsg:102719 -t_srs epsg:102719 test_temp.tif test_final.tif
It seems that
1. Imagine format is not right for holding ground control points.
Use GeoTIFF instead.
2. It may be not good to give -a_srs together with -gcp for gdal_translate.
At least it is not necessary. Just add gcp's first.
-Jukka Rahkonen-
