[gdal-dev] georeference and project a jpeg
jdmorgan
jdmorgan at unca.edu
Fri May 25 12:44:42 EDT 2012
I am sending this because I just realized that I posted w/ the wrong
subject so that it gets filed correctly in the archive:
This is a great listserv!
Chaitanya using a vrt worked so thank for that tip. Also, it must be the
case as Jukka says that img isn't holding the control points. But as
suggested a GeoTiff (and VRT) work fine.
Thanks so much for your help.
Cheers,
Derek
On 5/25/2012 3:00 AM, Chaitanya kumar CH wrote:
> Derek,
> Please provide the gdalinfo output of the img file.
> Also, try this:
> Create a vrt file instead of a HFA using the same gdal_translate
> command. See if gdalwarp works with the vrt file.
> On Fri, May 25, 2012 at 7:17 AM, jdmorgan <jdmorgan at unca.edu
> <mailto:jdmorgan at unca.edu>> wrote:
> Hello,
> I am attempting to georeference and project a jpeg image using
> only gdal tool.I have georeferenced the jpeg using the following
> command:
> gdal_translate -a_srs EPSG:102719-of HFA -gcp 0.0 0.0
> -82.5586187839508 35.59414007259327 -gcp 0.0 410.0
> -82.55858659744263 35.5937998255945 -gcp 520.0 0.0
> -82.55741715431213 35.594340730401775 -gcp 520.0 410.0
> -82.55728840827942 35.5940266570877NCDCLogo.jpg NCDCLogo.img
> The command run fine and produces a img file however it does not
> line up with similarly project layer per the gcp’s.When I check
> the projection information the file shows to be unprojected.
> Further, when I attempt to project the resulting raster with
> gdalwarp I get the following errors:
> “There is no affine transformation and no GCPs.”
> Any pointers here would be greatly appreciated.
> Thanks,
> Derek
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Derek @ NEMAC
http://nemac.unca.edu
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120525/e77b1946/attachment.html
