[gdal-dev] __main__.gdal_config_error when trying to install gdal
Chao YUE
chaoyuejoy at gmail.com
Sun May 27 12:13:52 PDT 2012
Dear all,
I am new to gdal and when I try to install it on my ubuntu computer, I have
the following error. It occurs either with pip or with manual python
setup.py build.
could anyone give me some clue on this problem? thanks in advance.
Chao
chaoyue at chaoyue-Aspire-4750:~/python/python_lib/build/gdal$ sudo python
setup.py install
[sudo] password for chaoyue:
running install
Checking .pth file support in /usr/local/lib/python2.7/dist-packages/
/usr/bin/python -E -c pass
TEST PASSED: /usr/local/lib/python2.7/dist-packages/ appears to support
.pth files
running bdist_egg
running egg_info
writing GDAL.egg-info/PKG-INFO
writing top-level names to GDAL.egg-info/top_level.txt
writing dependency_links to GDAL.egg-info/dependency_links.txt
File "setup.py", line 267, in <module>
ext_modules = ext_modules )
File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/usr/lib/python2.7/dist-packages/setuptools/command/install.py",
line 73, in run
self.do_egg_install()
line 93, in do_egg_install
self.run_command('bdist_egg')
File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py",
line 172, in run
self.run_command("egg_info")
cmd_obj.run()
File "/usr/lib/python2.7/dist-packages/setuptools/command/egg_info.py",
line 179, in run
self.find_sources()
line 254, in find_sources
mm.run()
line 308, in run
self.add_defaults()
line 332, in add_defaults
sdist.add_defaults(self)
File "/usr/lib/python2.7/dist-packages/setuptools/command/sdist.py", line
191, in add_defaults
build_ext = self.get_finalized_command('build_ext')
File "/usr/lib/python2.7/distutils/cmd.py", line 312, in
cmd_obj.ensure_finalized()
File "/usr/lib/python2.7/distutils/cmd.py", line 109, in ensure_finalized
self.finalize_options()
File "setup.py", line 164, in finalize_options
self.gdaldir = self.get_gdal_config('prefix')
File "setup.py", line 144, in get_gdal_config
return fetch_config(option)
File "setup.py", line 97, in fetch_config
raise gdal_config_error, e""")
File "<string>", line 4, in <module>
__main__.gdal_config_error: [Errno 2] No such file or directory
Chao YUE
Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
UMR 1572 CEA-CNRS-UVSQ
Batiment 712 - Pe 119
91191 GIF Sur YVETTE Cedex
Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120527/fda95c54/attachment.html>
