[gdal-dev] __main__.gdal_config_error when trying to install gdal
Chao YUE chaoyuejoy at gmail.com
Sun May 27 13:39:31 PDT 2012
Finally I managed to install gdal 1.6.3 using a debien package (and I have
to install libgdal1-1.6.0 before ). But I read from
http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
saying that from version 1.7.0, python 3 is needed.
thanks et cheers,
Chao
2012/5/27 Chao YUE <chaoyuejoy at gmail.com>
> Dear all,
> I am new to gdal and when I try to install it on my ubuntu computer, I
> have the following error. It occurs either with pip or with manual python
> setup.py build.
> could anyone give me some clue on this problem? thanks in advance.
> Chao
> chaoyue at chaoyue-Aspire-4750:~/python/python_lib/build/gdal$ sudo python
> setup.py install
> [sudo] password for chaoyue:
> running install
> Checking .pth file support in /usr/local/lib/python2.7/dist-packages/
> /usr/bin/python -E -c pass
> TEST PASSED: /usr/local/lib/python2.7/dist-packages/ appears to support
> .pth files
> running bdist_egg
> running egg_info
> writing GDAL.egg-info/PKG-INFO
> writing top-level names to GDAL.egg-info/top_level.txt
> writing dependency_links to GDAL.egg-info/dependency_links.txt
> Traceback (most recent call last):
>   File "setup.py", line 267, in <module>
>     ext_modules = ext_modules )
>   File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
>     dist.run_commands()
>   File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
>     self.run_command(cmd)
>   File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
>     cmd_obj.run()
>   File "/usr/lib/python2.7/dist-packages/setuptools/command/install.py",
> line 73, in run
>     self.do_egg_install()
> line 93, in do_egg_install
>     self.run_command('bdist_egg')
>   File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
>     self.distribution.run_command(command)
>     cmd_obj.run()
>   File "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py",
> line 172, in run
>     self.run_command("egg_info")
>     cmd_obj.run()
>   File "/usr/lib/python2.7/dist-packages/setuptools/command/egg_info.py",
> line 179, in run
>     self.find_sources()
> line 254, in find_sources
>     mm.run()
> line 308, in run
>     self.add_defaults()
> line 332, in add_defaults
>     sdist.add_defaults(self)
>   File "/usr/lib/python2.7/dist-packages/setuptools/command/sdist.py",
> line 191, in add_defaults
>     build_ext = self.get_finalized_command('build_ext')
>   File "/usr/lib/python2.7/distutils/cmd.py", line 312, in
>     cmd_obj.ensure_finalized()
>   File "/usr/lib/python2.7/distutils/cmd.py", line 109, in ensure_finalized
>     self.finalize_options()
>   File "setup.py", line 164, in finalize_options
>     self.gdaldir = self.get_gdal_config('prefix')
>   File "setup.py", line 144, in get_gdal_config
>     return fetch_config(option)
>   File "setup.py", line 97, in fetch_config
>     raise gdal_config_error, e""")
>   File "<string>", line 4, in <module>
> __main__.gdal_config_error: [Errno 2] No such file or directory
> Chao YUE
> Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
> UMR 1572 CEA-CNRS-UVSQ
> Batiment 712 - Pe 119
> 91191 GIF Sur YVETTE Cedex
> Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
Chao YUE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120527/2b74eacc/attachment.html>
