[gdal-dev] multiple bands in gdal2xyz.py should be comma separated
Even Rouault
even.rouault at mines-paris.org
Thu May 31 13:58:05 PDT 2012
Le jeudi 31 mai 2012 12:55:21, Tom van Tilburg a écrit :
> Hi,
> It seems that gdal2xyz.py currently supports the output of multiple
> raster bands using:
> gdal2xyz.py -band 1 -band 2 etc....
> However, when I use this in combination with the parameter -csv I do not
> get the extected comma in between the values of my bands.
> Extected: 5.604, 50.765, 3, 2
> Received: 5.604, 50.765, 3 2 <== "notice the missing komma"
> I briefly checked the python code and it seems to be an addition to
> 'band_format' is needed.
> band_format = ("%g " * len(bands)).rstrip() + '\n'
> should become something like
> band_format = (("%g " + delim) * len(bands)).rstrip(",") + '\n'
I've committed just a slightly different version in r24523 :
band_format = (("%g" + delim) * len(bands)).rstrip(delim) + '\n'
Thanks
> Cheers,
> Tom
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
