[gdal-dev] .tab to .mif with ogr2ogr
Wael Tarhouni
waelinsat at gmail.com
Thu Nov 1 03:34:21 PDT 2012
Hi All;
I'm tryin to convert a .tab file(Mapinfo) to a .mif file using the
following command :
ogr2ogr -f "MapInfo File" dst_datasource -dsco FORMAT=MIF src_datasource
but FWtools crashes !!
is there any problem with this command line ?
Best regards
Wael Tarhouni
Élève ingénieur en Réseaux informatiques et Télecommunication à l'INSAT
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121101/6cca1a92/attachment.html>
