[gdal-dev] .tab to .mif with ogr2ogr
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Nov 1 03:37:06 PDT 2012
Wael,
Can you give more details like the version of GDAL you are using and an
output of ogrinfo of the source?
(Use "ogr2ogr --version")
On Thu, Nov 1, 2012 at 4:04 PM, Wael Tarhouni <waelinsat at gmail.com> wrote:
> Hi All;
> I'm tryin to convert a .tab file(Mapinfo) to a .mif file using the
> following command :
> ogr2ogr -f "MapInfo File" dst_datasource -dsco FORMAT=MIF src_datasource
> but FWtools crashes !!
> is there any problem with this command line ?
> Best regards
> Wael Tarhouni
> Élève ingénieur en Réseaux informatiques et Télecommunication à l'INSAT
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121101/15d11b7c/attachment.html>
