[gdal-dev] .tab to .mif with ogr2ogr
Wael Tarhouni waelinsat at gmail.com
Thu Nov 1 03:48:19 PDT 2012
Chaitanya,
GDAL's version is 1.7.0b2 and FWTools's version is 2.4.7;
Regards
2012/11/1 Wael Tarhouni <waelinsat at gmail.com>
> Chaitanya,
> Regards
> 2012/11/1 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Wael,
>> Can you give more details like the version of GDAL you are using and an
>> output of ogrinfo of the source?
>> (Use "ogr2ogr --version")
>> On Thu, Nov 1, 2012 at 4:04 PM, Wael Tarhouni <waelinsat at gmail.com>wrote:
>>> Hi All;
>>> I'm tryin to convert a .tab file(Mapinfo) to a .mif file using the
>>> following command :
>>> ogr2ogr -f "MapInfo File" dst_datasource -dsco FORMAT=MIF src_datasource
>>> but FWtools crashes !!
>>> is there any problem with this command line ?
>>> Best regards
>>> Wael Tarhouni
>>> Élève ingénieur en Réseaux informatiques et Télecommunication à l'INSAT
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
> Wael Tarhouni
Wael Tarhouni
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121101/535dddc6/attachment.html>
