[gdal-dev] [Osgeo4w-trac] random crashes upon using ogrinfo or ogr2ogr with FileGDB
Martin Feuchtwanger
feumar at shaw.ca
Wed Nov 7 17:13:36 PST 2012
Jeff McKenna suggested (privately) that i try MS4W. He didn't really say why, and i suspected it wouldn't work because both OSGeo4W and MS4W seem to use the same version of the FileGDB driver (at least, both FileGDBAPI.dll files are identical).
However, MS4W is still using GDAL 1.9.1 (2012/05/15) while OSGeo4W is now using GDAL 1.9.2 (2012-10-08), and, running the same ogrinfo and ogr2ogr tests (via OSGeo4W) on GDB files, there are no more crash problems!
Thus, there seems to be a problem with GDAL in the change from 1.9.1 (2012/05/15) to 1.9.2 (2012-10-08), when using FileGDB.
I'm very new here -- should i be reporting this elsewhere?
Martin Feuchtwanger feumar at shaw.ca 604-254-0361
On 06/11/2012 4:25 PM, Martin Feuchtwanger wrote:
> Using GDAL-OGR 1.9.2 (2012-10-08) with the FileGDB add-on (not sure
> of the version, but i got it at the same time i got GDAL), there's a
> random crash bug upon using ogrinfo or ogr2ogr.
> I've tried the following on several different GDB files and there's
> almost always a Windows error message:
> ogrinfo.exe has stopped working
> A problem caused the program to stop working correctly....
> but it's not always at the same time during the processing.
> ogrinfo --debug on -al <gdb_file>
> OGR: OGROpen(<gdb_file>/02DAE9F8) succeeded as FileGDB.
> OGR: GetLayerCount() = <N>
> It usually appears here, and no layers are listed, but sometimes they
> do get listed
> 1: <layer1> (Multi Line String)
> 2: <layer1> (None)
> N: <layerN> (Multi Polygon)
> before the crash. Sometimes the crash occurs part-way through.
> The same crash happens when using ogr2ogr to write a GDB file to Postgres:
> ogr2ogr -overwrite --debug on -f "PostgreSQL" PG:<DB_connection>
> <gdb_file>
> ogr2ogr.xe has stopped working
> I've seen references to using a patch to make 4GB available (instead
> of 2GB) for \Program Files (x86)\ programs
> http://ntcore.com/4gb_patch.php but the problem persists even for
> small GDB files.
> I'm guessing it /is /a memory issue, though, because of it's varying
> behavior on my machine and, presumably, has not occurred on the
> programmer's machine.
> BTW, the problem seems quite /independent /of the "Invalid function
> arguments." error resulting from the GDB having a non-standard CRS --
> it happens with GDBs having a standard CRS too.
> Is it possible the FileGDB driver is broken?
> Martin Feuchtwangerfeumar at shaw.ca 604-254-0361 Vancouver, BC
> Osgeo4w-trac mailing list
> Osgeo4w-trac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-trac
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121107/8f66811d/attachment.html>
