[gdal-dev] Cannot get spatial reference system from ozi file
Nik Sands
nixanz at nixanz.com
Sun Nov 11 19:38:47 PST 2012
Please ignore this thread. I've finally figured out that it was an error in code on my part. I thought that my code was reading the .map file, when in fact it was reading the GeoTIFF file that had been converted from the .map/ozf2 earlier in the program. My humble apologies.
(I may post a new thread later regarding why the GeoTIFF is not georeferenced correctly).
Thanks for your tolerance. :-)
Nik.
On 12/11/2012, at 12:45 PM, Nik Sands <nixanz at nixanz.com> wrote:
> I still don't have any resolution to this issue, but thanks to feedback from one list reader, I've been prompted to find out some more information...
> gdalinfo produces the following output, which is contrary to what my application produces:
> Coordinate System is `LOCAL_CS[""Ozi" projection "(UTM) Universal Transverse Mercator"",UNIT["Meter",1]]'
> So I need to figure out why my application is not getting this from the same file.
> Note that my build of GDAL is from a recent version of the trunk (September, 2012):
> $ gdalinfo --version
> GDAL 2.0dev, released 2011/12/29
> And was built for Mac OS X using the following configure (which I noted at the time for future reference as it took me ages to get this to work :-):
> ./configure \
> --with-macosx-framework \
> --with-threads \
> --disable-static \
> --without-pg \
> --without-grass \
> --without-libgrass \
> --without-cfitsio \
> --without-pcraster \
> --without-netcdf \
> --without-ogdi \
> --without-fme \
> --without-hdf4 \
> --without-hdf5 \
> --without-jasper \
> --without-kakadu \
> --without-bsb \
> --without-grib \
> --without-mysql \
> --without-ingres \
> --without-xerces \
> --without-odbc \
> --without-curl \
> --without-sqlite3 \
> --without-idb \
> --without-sde \
> CFLAGS="-Os -arch i386 -arch x86_64" \
> CXXFLAGS="-Os -arch i386 -arch x86_64" \
> LDFLAGS="-arch i386 -arch x86_64"
> On 07/11/2012, at 11:11 AM, Nik Sands <nixanz at nixanz.com> wrote:
>> Hi all,
>> My application is reading in ozi file pairs (.ozf2/.map), warping them and saving out as GeoTIFF or other file formats using GDAL. It works fine for my own ozf files, but not for the files sent to me by one of my users (who apparently has a large number of files they want to use).
>> It has been unable to get a useful spatial reference system from the ozi file pair (.ozf2/.map) sent to me (.map content below). The following code:
>> OGRSpatialReferenceH srcSRS = OSRNewSpatialReference(pszSrcWKT);
>> char *srcWKT;
>> OSRExportToWkt(srcSRS, &srcWKT);
>> printf("\n%s\n\n", srcWKT);
>> produces the following output:
>> LOCAL_CS["unnamed",UNIT["unknown",1]]
>> Can somebody please help me to use GDAL to obtain a valid spatial reference system from this .map file (content below)?
>> Note that I'm using a fairly recent build of GDAL trunk that includes all the ozi datums, etc, including "Australian Geodetic 1966" and it is able to get a valid SRS from my own files that use the same ozi datum.
>> The complete content of the ozi .map file in question is below.
>> Thanks in anticipation,
>> Nik.
>> OziExplorer Map Data File Version 2.2
>> r2256.jgw
>> D:\Documents and Settings\nelsonp\My Documents\General Admin\Personal\Tasmania 1 to 25,000\North West OZF2\r2256.ozf2
>> 1 ,Map Code,
>> Australian Geodetic 1966,WGS 84, 0.0000, 0.0000,WGS 84
>> Reserved 1
>> Reserved 2
>> Magnetic Variation,,,E
>> Map Projection,(UTM) Universal Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
>> Point01,xy, 0, 0,in, deg, , ,, , ,, grid, 55,219999.09067205,5570000.7412442,S
>> Point02,xy, 1000, 1000,in, deg, , ,, , ,, grid, 55,223259.16350298,5566740.6684133,S
>> Point03,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point04,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point05,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point06,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point07,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point08,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point09,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point10,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point11,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point12,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point13,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point14,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point15,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point16,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point17,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point18,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point19,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point20,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point21,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point22,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point23,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point24,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point25,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point26,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point27,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point28,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point29,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Point30,xy, , ,in, deg, , ,, , ,, grid, , , ,
>> Projection Setup, 0.000000000, -120.000000000, 0.999600000, 0.00, -4000000.00, 34.000000000, 40.500000000,,,
>> Map Feature = MF ; Map Comment = MC These follow if they exist
>> Track File = TF These follow if they exist
>> Moving Map Parameters = MM? These follow if they exist
>> MM0,Yes
>> MMPNUM,4
>> MMPXY,1,0,0
>> MMPXY,2,6136,0
>> MMPXY,3,6136,3069
>> MMPXY,4,0,3069
>> MMPLL,1, 143.721340, -39.973660
>> MMPLL,2, 143.955261, -39.980047
>> MMPLL,3, 143.951253, -40.070068
>> MMPLL,4, 143.717025, -40.063661
>> MM1B,3.251882
>> MOP,Map Open Position,0,0
>> IWH,Map Image Width/Height,6136,3069
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
