[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Nik Sands
nixanz at nixanz.com
Tue Nov 13 15:44:45 PST 2012
Thanks very much for looking into this. I've filed the bug at https://trac.osgeo.org/gdal/ticket/4894
On 13/11/2012, at 10:02 PM, Jean-Claude Repetto <jrepetto at free.fr> wrote:
> Le 13/11/2012 01:03, Nik Sands a écrit :
>> Thanks for the replies so far. Unfortunately, adding a 3rd calibration point to the .map file has not helped. Of course I'm assuming that the added calibration point is valid (eg, I tried the one suggested below, which looks like it should be OK).
>> Does anybody have any other suggestions as to why this .map file cannot be interpreted correctly by GDAL?
>> Is it a bug, or an incomplete .map parsing implementation, or am I doing something wrong?
> Hi Nik,
> I have looked at the Ozi driver source code, and found that the UTM projection is not supported.
> Please file a bug (https://trac.osgeo.org/gdal/), provide some sample files, and I'll try to improve the driver.
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
