[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Jean-Claude Repetto jrepetto at free.fr
Tue Nov 13 03:02:18 PST 2012
Le 13/11/2012 01:03, Nik Sands a écrit :
> Thanks for the replies so far.  Unfortunately, adding a 3rd calibration point to the .map file has not helped.  Of course I'm assuming that the added calibration point is valid (eg, I tried the one suggested below, which looks like it should be OK).
> Does anybody have any other suggestions as to why this .map file cannot be interpreted correctly by GDAL?
> Is it a bug, or an incomplete .map parsing implementation, or am I doing something wrong?
Hi Nik,
I have looked at the Ozi driver source code, and found that the UTM
projection is not supported.
Please file a bug (https://trac.osgeo.org/gdal/), provide some sample
files, and I'll try to improve the driver.
Jean-Claude
