[gdal-dev] Reading DNG files with GDAL
Even Rouault
even.rouault at mines-paris.org
Wed Nov 21 11:22:40 PST 2012
Le mercredi 21 novembre 2012 19:56:31, Scott Arko a écrit :
> Hello,
> I have run into a strange issue that I haven't been able to sort out. I
> have a number of digital negative (.dng) files collected by an Aeryon Scout
> UAV. They are three band images with the bands being UInt16. However,
> when I read these images with the python gdal binding, they read as Byte
> bands and half resolution. When I use gdalinfo I get something like:
> Driver: GTiff/GeoTIFF
> Files: 2012-11-06-flight_005-012.dng
> Size is 1296, 972
> Coordinate System is `'
> Metadata:
> TIFFTAG_DATETIME=2012:11:06 16:24:42
> TIFFTAG_SOFTWARE=Aeryon_Scout_DNG
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 972.0)
> Upper Right ( 1296.0, 0.0)
> Lower Right ( 1296.0, 972.0)
> Center ( 648.0, 486.0)
> Band 1 Block=1296x2 Type=Byte, ColorInterp=Red
> Band 2 Block=1296x2 Type=Byte, ColorInterp=Green
> Band 3 Block=1296x2 Type=Byte, ColorInterp=Blue
> In reality, the data are 2592X1944 and the bands are UInt16. I can read
> the files with ufraw and they read fine. Interestingly, Python Imaging
> Library (PIL) also reads them like gdal.
> Running gdal 1.9.0 on a MBP with Snow Leopard
> Would appreciate any thoughts folks might have.
I'm not a specialist of DNG files but I somehow remember that they are a kind
of "weird"/unusual TIFF Files. It might be possible that GDAL (or probably
libtiff) has found a overview instead of the full resolution imagery. Perhaps
you could provide a sample for examination.
> Thanks,
