[gdal-dev] Mixed SRSes ?
Pierrick.BRIHAYE at region-bretagne.fr
Fri Nov 30 04:52:57 PST 2012
Hello,
When I try to export some GML files to .shp (using : .\bin\ogr2ogr.exe -f
"ESRI Shapefile" polygons.shp polygons.gml -t_srs EPSG:27572 -nlt POLYGON
-lco ENCODING=ISO-8859-1), with ogr2ogr version "GDAL 1.9.2, released
2012/10/08" on Windows, I get :
Can't transform coordinates, source layer has no
coordinate system. Use -s_srs to set one.
I guess this is due to mixed SRSes in my files (namely "
http://www.opengis.net/gml/srs/epsg.xml#27572" and ""
http://www.opengis.net/gml/srs/epsg.xml#27562").
If so, how could I get around my problem ?
Cheers,
Pierrick Brihaye
Coordinateur du pôle ressources / médiation
SINPA / DTP
Conseil Régional de Bretagne
2 rue Gabriel Germain
35000 Rennes
+33 2 22 93 98 24
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121130/763dca63/attachment.html>
