[gdal-dev] Problem installing gdal from source - dxf-related?
Even Rouault even.rouault at mines-paris.org
Mon Oct 1 07:33:31 PDT 2012
Andreas,
I suspect that your source files don't match the "official" ones. The line
numbers don't point to the line numbers of the SVN version. There must have been
an error in the process when you updated your source files.
Even
