[gdal-dev] Gdal 1.9 and ERDAS Read-Write SDK write projection
Even Rouault even.rouault at mines-paris.org
Tue Oct 2 05:07:38 PDT 2012
Selon netcadturgay <turgay.osna at netcad.com.tr>:
> I open an ECW file in Update mode. Then I set to the projection
> information(with SetProjection method) but ecw file does not change. How can
> I solve this problem?
Did you close properly the dataset ? The ECW header is only rewritten with the
updated information at dataset closing.
