[gdal-dev] Gdal 1.9 and ERDAS Read-Write SDK write projection
netcadturgay turgay.osna at netcad.com.tr
Tue Oct 2 05:37:09 PDT 2012
Yes, I close the dataset properly and now I found problem source. If I try to
set the "Geodesic WGS84", it updates successfully. But if I try to set the
custom projection, it does not update?
*Custom WKT*
PROJCS["(UTM)Universal Transvers Merkator 6º",GEOGCS["EUROPEAN
1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.0,297.0],TOWGS84[-87.0,-98.0,-121.0,0.0,0.0,0.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],PARAMETER["SCALE_FACTOR",0.9996],PARAMETER["CENTRAL_MERIDIAN",33.0],PARAMETER["LATITUDE_OF_ORIGIN",0.0],PARAMETER["FALSE_EASTING",500000.0],PARAMETER["FALSE_NORTHING",0.0],UNIT["meter",1.0]]
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-write-projection-for-ecw-files-in-Gdal-1-9-including-ERDAS-Read-Write-SDK-tp5005832p5005850.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
