[gdal-dev] MinGW build
Ari Jolma
ari.jolma at gmail.com
Fri Oct 5 07:54:09 PDT 2012
Folks
I'm building GDAL (the trunk) in latest MinGW. For some reason I don't
understand I need to add -lstdc++ to LDFLAGS in GDALmake.opt. I'm not
sure if this is the best way to fix the problem - probably not - but it
works. The problem is the step where the library file libgdal.dll.a is made.
Anybody have any ideas why this is like this? Otherwise
http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW seems up to date.
Ari
