[gdal-dev] OGR SQL: Excecuting select where column name contains "."
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Oct 8 13:21:37 PDT 2012
Even Rouault wrote:
>> I can confirm that it is not illegal per se because the following works. I
>> hope that the backslashes and everything go through properly.
>> ogrinfo WFS:http://188.64.1.61/cgi-bin/tinyows
>> -sql "select \"nom.dept\" from \"tows:dot.test\""
>> It is an open WFS server and you can test it with ogrinfo and from your
>> code too. However, I will remove the dot.test feature type sooner or
>> later. Verify and make your code to work in a similar way than ogrinfo.
> Jukka,
> I didn't do any test up to now, but now that I've tested with your above
> server, here are my findings and conclusions.
> To start, I'm wondering to which extent did you check the result of the above
> ogrinfo command. It "works" for me on GDAL 1.9.2 and GDAL trunk on Linux and
> Windows, but the output is what Odd-Ragna actually observes, something like :
> FIELD_1: String (0.0)
I feel ashamed and made one more test to compansate my lazy interpretation that if TinyOWS is sending something back it is then all right.
HTTP POST tends to be more reliable when making complicated WFS requests so I tried that method by sending directly to the server the following GetFeature:
POST http://188.64.1.61/cgi-bin/tinyows HTTP/1.1
Content-Type: text/xml
User-Agent: Jakarta Commons-HttpClient/3.0-beta1
Host: 188.64.1.61
Connection: Keep-Alive
Content-Length: 404
<wfs:GetFeature xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0" maxFeatures="1000" outputFormat="GML2"><wfs:Query xmlns:tows="http://www.tinyows.org/" typeName="tows:dot.test"><ogc:PropertyName>tows:nom.dept</ogc:PropertyName><ogc:PropertyName>tows:the_geom</ogc:PropertyName></wfs:Query></wfs:GetFeature>
TinyOWS gives an error
<ServiceExceptionReport
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.1.1/OGC-exception.xsd"
version="1.2.0">
<ServiceException code="NoMatching" locator="GetFeature">
propertyname values and typename values don't match</ServiceException>
</ServiceExceptionReport>
There may be something wrong with TinyOWS but it must be noted that it has passed all the CITE tests for WFS 1.0.0 and 1.1.0. If so well tested server fails with dots in the field names it is very probable that there are lots of other servers and clients which will fail too.
Conclusion: Do not use dots in names if you hope it to work.
-Jukka-
